02.20.2007, 12:46 PM
Originally Posted by squeeforever
Try moving the RX.
That was my first thought as well.
02.20.2007, 12:52 PM
FWIW, I had a brand new Spektrum receiver with occasional problems and it turned out to be the antenna wire.
BTW: Replacing the antenna wire on a Spektrum is a PITA! They solder the wire right next to a few itty bitty surface mount components and then the use some kind of rubbery glue stuff to help hold the antenna in place.
02.20.2007, 12:55 PM
ARG! So I should check out that connection...ok.
02.20.2007, 04:56 PM
I hope for your sake that it's not that. It was a real PITA to replace the wire - and I don't exactly consider myself a soldering novice. The glue stuff had to be carefully scraped off and the tiny solder point for the antenna doesn't allow anything larger than 22 or 24 Ga wire (at a guess). And then you have to be careful not to heat the solder point too much because of the SM components nearby (about 2mm away).
02.20.2007, 06:38 PM
I had to re-solder mine too, it was no easy task, but with a small 20 watt soldering iron, it made it alot easier!
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
02.20.2007, 09:01 PM
Lucky you - all I had was a 40w iron (with a fairly large tip). I am able to reduce the heat with a homemade temp control though, so that helped. Made me a bit nervous to do that on a brand new Spektrum module, but really wasn't since I technically had it for about 3-4 months.
02.20.2007, 09:10 PM
Yea, i cant imagine using a tip almost as big as the board being worked on! ;)
Losi 8ight e
02.20.2007, 11:44 PM
Lol, tell me about it. Kinda like using a jackhammer to do cabinetry. :)
02.21.2007, 12:58 AM
I'm going to ask a dumb question. Did you program the ESC for the new radio?
02.21.2007, 01:28 AM
Another thought is that, could your fail-safe mode on the radio is set at WOT. I don't know why it would go into fail-safe mode though.
02.21.2007, 01:25 PM
I did. Always do with a new rx and or radio. I like to make sure the settings are read by the esc properly and all that since I'm not familiar with it all. I may just put the rx in my jato to see how it responds in there. If that just takes off, i really don't care as much. it's what i got it for! LOL, but my maxxes are not cheap to repair like the jato....
Hyper 7 Erevo Center Diff
02.21.2007, 07:40 PM
did you get it figured out yet?
02.22.2007, 10:03 AM
Not yet. Been busy with school....to rule out the rx though, I'm gonna throw it in my Jato. It's the RS300, I use the RS310 but it should still work fine just for testing. I tried moving the rx but it didn't help. If the rx works fine in the jato then I'm leaning towards the li saver. The other thing I was thinking was a low rx pack.....so we will see.
