renny
if you build it.... Then I can break it
renny's Avatar
02.22.2007, 06:06 AM
because i`m a basher I have already know the results of mud and water so I have waterproofed the servos with some liquid electrical tape which when dry turns into a rubber seal that I have also used on my rc boats and works awsome but my problem is the ESC, UBEC,and motor.I think your onto something with the water tight box but im not sure about the temps on the ESC.Just throwing around ideas here......
What about a enclosed box that will contain the ESC and UBEC and some sort of cooling fan inside?As far as the motor goes i`m thinking of trying my liquid tape on the wire side and a rubber Oring on the front side.
How does that sound?
