02.23.2007, 06:46 PM
First of all; Welcome to the forums!
You'll find that most people use "only" one brushless motor because that's all you really need. If you want more power, get a bigger motor. With two ESCs and motors, there might be a chance that they would run at different rates reducing efficiency. Plus, you'd need one heck of a battery setup to have enough of a discharge rating for two systems.
I'm sure it IS possible, just not sure if the end result would justify the expense and trouble.
