supermaxx4190
supermaxx4190's Avatar
06.23.2005, 05:12 PM
hey batfish, i just talked to the enginner of the LVC and he said i could connect it to only my 2s pack and that would cut my throttle when that pack hits 6 volt which means if my other pack is at the same charge state as the 2s, they will all be at about 3 volts per cell. i am going to need a special LVC which they are going to make for me when i order it. it has something to do with the spikes of amps in cars, so i think he is going to program it a little different.
BTW mike, kokam is not planing on making any bigger compasity cells, but are coming out with a new line that will have up to a 3p6s built from 3200 cells . its a whole new line and you will have to use a special charger and voltage cutoff device that moniters each cell. sounds cool but expensive.
mike, do you use any voltage cutoff device?
