GriffinRU
02.26.2007, 09:57 PM
Ok,
If you do not plan to use more then 16 cells then do not buy 24cells version. 24 cells version rated for 160A but capacitors which they use are not rated for that current. Bottom line you will gain higher efficiency running high voltage but you need to sacrifice current in order to achieve reliability, otherwise you will smoke MGM if not on the first run then on the second one for sure.
Artur
