03.03.2007, 01:07 AM
OK, I had some more time to really look into it and run it.
Pros
  • It's fast
  • It's RTR complete with motor, ESC, radio, lipos. You have to supply the 8 AA's for the transmitter.
  • Brand name ESC (Mamba 25) and motor (Himax).
  • No radio signal glitching.
Cons/Observations
  • No center diff.
  • Internal front/rear diff gears are plastic. Haven't confirmed this, but that's what the manual said. Maybe that's actually OK for something this size, I dunno.
  • IMO, layout needs to be changed because the steering servo screw is VERY close to the lipo pack and there's potential for a puncture. So, I swapped around the bellcrank and servo to the other side. Plenty of wiggle room for the lipo pack now, but the ESC and receiver have to be relocated as well since the servo arm and linkage are in the way of the stock locations. ESC was relocated to the top plate.
  • ESC gets quite warm, ~150*F after a few minutes. Maybe it's the relatively hot motor (5300 kv) running at 3s with a small ESC. So, I added a heatsink to the FETs and re-heatshrinked ala BK Warrior style. Still gets warm (~130) but better. Probably runs better when not doing so much partial load running, but can't verify this since the thing is too fast for the basement. :)
  • The pinion came loose so I had to grind a slight flat spot on the shaft. I also Lock-Tite'd it just as an extra precaution. The set screw was a PITA to loosen and re-tighten. It feels like the set screw threads in the pinion aren't cut right or something.
  • The radio is hard to calibrate to the ESC. Throttle has to be reversed and the trim has to be set biased 3/4 the way torwards the reverse direction in order for the ESC to recognize reverse.
  • There's something up with the front diff. When running in the air, one side tends to turn faster than the other, but it seems to run fine on the ground.
  • ESC tends to pulse when running slow. Not cogging, but the buggy moves about a foot, stops, moves another foot, etc. It's definitely meant for high speed running. Smooth operation from about 5mph+.
  • The radio charging jack does not work with a standard peak detection charger. There's a circuit in the radio that keeps the charger from reading the voltage level of the batts, so it's meant to charge using a simple "wall-wart". I modded the radio so the jack is wired directly to the batteries and now fits RadioShack size "N" (IIRC) power jack, which is what I use in my Spektrum. Charging is now possible with any deak-detection charger.
  • ESC and lipo pack come with Tamiya connectors. Worked OK, but swapped over to Deans anyway.
So, is this thing worth the $239 pricetag? I personally don't think so, but I have exacting standards so I'm not sure. I guess I expected something closer to the quality of an 1/8th scale, just smaller. This isn't it.
I don't see this as being something I'll be running a lot and will most likely sit on the shelf collecting dust. :sigh: Anyone want a good deal on a slightly used (and somewhat improved) Photon?
