MM and neu
nl12
nl12's Avatar
MM and neu - 03.06.2007, 02:05 PM
Is the MM updated to work with 4 pole motors like the neu yet?
Thanks
03.06.2007, 02:14 PM
No software update yet. People seem to have better results by direct soldering the motor wires to the ESC (no connectors), but the issue is still there, just reduced.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.06.2007, 02:27 PM
Small update from me... I'm retesting the lipo packs at lower temps which equals more voltage drop on hard accel.
I am seeing a little more cogging now than when I had the packs nice and warm... still pretty smooth if you give it a chance to start moving before hammering the throttle. But it you hammer it while it's stopped... sometimes it cogs. Sometimes bad..
But, it's good if you remember not to jam throttle until it's at least creeping a little.
Again... the warm packs yesterday did better. The voltage never really dipped below 13V. Today I'm getting some dips below 12V. So maybe that's why I'm seeing more cogging...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
