glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.08.2007, 12:03 PM
The temps lok ok... that's about the hottest I have ever had a lipo get but it should not do any harm.
The buggy it kinda heavy... mine only weigh a tiny bit more than nitro, with a 6000-8000mah pack.
But since it's heavier, you do need to run a heavier oil in the shocks along with the stiffer springs. The oil damping has a lot to do with the car absorbing impact on landing. You could also swap out to a smaller piston and keep the oil the same. That tends to help bottoming out a lot.
But... all 1/8 bottom out anyway at least sometimes
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
