I found the problem!!!!!! I was still using a on/off switch between the ESC and rx and as I was going over all the wires while installing the Spektrum rx I noticed a very small cut in the switch wire. It was a deep enough cut that at least half the wire was severed. I pulled the switched out.....never really needed it anyway....and all my problems are gone!!!!!!
