glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.13.2007, 02:14 AM
You have 3 major taps on the market now:
Thunderpower
Polyquest
Align
Each have a number of manufacturers following one of the above. For example,
Align is the same as 3e Models, Electrifly, E-Flight or most any Chinese battery.
Thunderpower is also the same as Apex, Flightpower.
Polyquest taps are also used by Hyperion, Max Amps, E-Tec
Kokam is also the same as Graupner.
From a post on another site... not my info... I have to assume this is accurate...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
