skellyo
skellyo's Avatar
03.15.2007, 11:06 AM
Originally Posted by elegal
2. I am almost done converting a LSP-R to brushless, and am going to get two trakpower 4900 batteries. Can I stack these in the same mount on top of each other, or will I have overheating issues with the packs? Also, does anyone have a pic of the setup to use when balancing these packs?
No, they can't be stacked because the connector terminals are located on top of the packs. You'd have to have them offset by about 1/2" to be able to plug the 4mm connectors in both.
3. Assuming I buy two trakpowers, can I use the Flightpower V-Balancer to balance both trakpowers at the same time (would be like one 4S pack)? I also want to be able to balance the Apogee packs, so would it be easier to use the trakpower adaptor for the V-balancer (to balance the trakpowers) and use the taps that come with the V-Balance to balance the apogee packs?
No, you need an adapter specific to the Trakpowers. If you don't have a V-Balance already, you can buy a version that comes with the Trakpower adapter included. It will also charge their standard Flightpower Lipos with the proper harnesses. Also, it's $5 cheaper than the standard V-Balance and then you don't need the $7 adapter harness for the Trakpowers. If you plan to order Trakpowers, speak with a gentleman named Jack at Duralite...very helpful guy and will make sure you get what you need.
