glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.25.2007, 11:37 PM
Very nice work.
I bet a 5s 5000mah pack would work nice with that setup... shed a little weight and give it the extra rpms it needs. I'm not sure about the MM on 5s though...
The off throttle push is a bit different with no f/r brake bias. I dial in the drag brake where I want it and if it still pushes into the corners... you have to drive it different than a nitro. Brake a little earlier and roll the corner more.. and you can come back on throttle sooner coming out, in general.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
