glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.31.2007, 11:11 AM
copied form pm....
I would set it:
Lion
3 cell
6900mah
current: 6.9 amps
max capacity: 30%
If the pack is dumped.. then this will fast charge it to about 2000-2100 mah which should have it close to fully charged. (only @ 20 minutes)
If the volts don't hit a full 10.8-11v then you could bump it again to top it off.
If you don't want to do (3c) 6.9 amps... drop it to this(2c):
4600mah
4.6 amps
max charge: 45%
@ 30 minutes...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
