03.31.2007, 10:18 PM
Oh, ok. The Revo tranny. You can also go with the wide ratio gear set which gears it up a little if you run into trouble getting spur/pinion of the right size. FYI: First gear on the wide ratio is the same ratio, only second gear changes. Not a big deal since I removed first gear altogether and locked it in second...
