crazyjr
crazyjr's Avatar
04.02.2007, 06:46 PM
Originally Posted by neweuser
I personally have never used the CC link, but then again, i only have the mm 25....
Other than that, with all the issues i have heard about the link I would hope they cure this problem.....MMM should be great, i just fear that it will take longer than anticipated....
Its not the mamba 25 or any other esc in castles lineup, all the forum threads and problems i have seen are with the mamba max, which strangely is the only one with a usb jack and not plugged into the reciever wire
I would believe the problem with the driver in the esc if the esc never worked on the computer, the newest one did just that, but run once before losing neutral, but the oldest one had been programmed several times in the n=early year i had it till V2.23
As I have said before to all new people, I love the mamba max system, I'm just concerned about the programon the computer
