Can the MM controller handle it though?I thought it's only officially rated for 3S,or are people running them over spec without problems?
Technically, 12 cells (which the manual says is ok) is the same voltage level as 4s, nominal and right off the charger. I don't know why they rate it 12 cells and only 3s.
