04.05.2007, 12:38 PM
The trouble with most two speed auto-shifting transmissions (which I'm assuming the MGT uses) is that there is a OWB on the first gear. This means that you won't be able to use motor braking and motor reverse. So, you'll have to use disc brakes with a servo, but I don't know about reverse. Not sure if this applies to the MGT, but it's something to think about...
