Gustav
Gustav's Avatar
04.05.2007, 01:09 PM
It's a schulze 330-d,it's really a trustworthy charger,i did take it off a couple of minutes early now you mention it,but it was down to below 50ma which normally means it's just about done,it'd been at 12.6 volts for a long time.also i kepted coming back inside and checking the resting voltage and it's lower now than it was then,still without the lvc kicking in,it's showing 11.4volts now.i'm going to go run it untill the LVC kicks in then charge it and see how much capacity it takes.
edit;no,charger settings were definately right.
