Before I go anywhere from here, I need a solution to a problem. A member from another forum brought up an issue about the motor braking with a center diff will only give breaking to the wheels with the least amount of traction and usually spin out the buggy. I was wondering if anyone had a suggestion for a fix to this problem without running mechanical brakes?
