04.07.2007, 02:50 AM
Lol! yeah, these tires weight a ton, only problem is that they use a non metric allen wrench...
Nice ride Wallot! you got some smoking friends around!! :p
when you jump, you need to go to 50-60 percent throttle, that way the car will stay stable in the air. if you go to WOT the truck will go backwards, and if you brake the truck will go forwards.
and you can also steer in the air, you don't need a perfect straight run to the jump. if you steer to the right in the air, the truck responds to this. The heavier the tires, the better the aircontrol.
Nice vids!
