A4DTM
04.07.2007, 05:11 PM
Originally Posted by skellyo
The only reason I think it might not be mountable in the front of the chassis, opposite the servo, is that the mount might extend past the chassis edge where it angles upward. A quick e-mail to Mike should answer the question though.
Personally, I like the idea of the motor behind the servo and batteries on the opposite side in order to better balance the chassis. Otherwise, you could end up with as much as ~14oz of more weight on one side than the other depending on how you mount your batteries.
hmm well i ordered one, so we'll see.. i'm running two battery packs, that's why i need a front left position on the motor.
