lol i knew you did, but was wondering if anyone else did. how did you get the HB lightning pro so early?? what are you running for power in that thing?
This is my second Lightning Pro - both Mike and I have had them since last season - Im running a Novarossi Medial Pro 2K - It seems pretty good - Its my first non RB .21 motor. Its good to have a motor that runs and idles...
I would guess a truggy would be described as a truck mated with a buggy - hence the name " Truggy " - It actually is a 1/8 scale size buggy ( or longer as the lightning stadium is )with longer suspension arms with monster truck rims and tires. It gives the perfomance of an 1/8 scale with ground clearance and stability. And if you were wondering - I will not be running my 1/8 scale buggy this season because this truggy is absolutely awesome and so much fun to drive...
I have a stretched titanium chassised dominator, the HB Lightning Pro, and a few g-maxxes (kind of electric truggies!). I never really dug the buggy conversions, though.
i got a Xtm mammy but no pics as of know mods are Hardbodyz cage Blue,1 5mm shock tower,upgraded front/rear braces,servo saver plate,main gear plate,aluminum servo saver and ofna pull starter.
The mammoth is definitely a MT
I always thought the definition of a Truggy is a vehicle with
A low center of gravity
Diffs that are mounted on top of the chassis
center diff
I may be wrong,but does the Mammoth have any of these? :D
