zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.07.2007, 11:27 PM
Geez Brian, you're doing more harm than good here! :005:
In reality, higher voltage will allow you to get a higher power from a given motor, that being said staying within a given RPM limit; I'm talking about scaling the system voltage ALONG with the motor KV (lower). This is because torque output goes up, efficiency goes up as well, that's if you stay within a couple 1k rpm, do you get what im saying? :032:
