Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
06.28.2005, 04:26 PM
For my xxx-t drivetrain, I run a 1 piece aluminum top shaft, kevlar spur gear, and high quality bearings. I can get around 20 runs usually. I've never tried an associated drivetrain, but if I were to build a truck specifically for brushless these days. It'd be an factory team t3 with all the rpm parts.
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
06.28.2005, 05:52 PM
The t3 is nearly bulletproof, especially with an alloy idler gear. Wolrds above Losi in terms of durability in the drive train.
rc freak
Going Fast Motorsports
06.28.2005, 05:58 PM
Another reason aassociated is better then losi people using ae stuff for there losi trucks make me laugh.
Go blue or get left in the dust. Yamaha Raptor 660r
Got Sand?
RC-Monster Mike
Site Owner
06.28.2005, 06:20 PM
I have to give it to Losi on the shocks, though. Excellent boingers.
EvaderAnubis
06.30.2005, 07:22 PM
Thanks For the short list SpEEdyBL and Re~Mix, will definately put those on my parts list.
Has anyone heard of TowerPro? I saw a servo and a few other parts from them that I may consider, but again since I'm new to the hobby I don't know if it's a known/good brand or not...
squeeforever
squeeforever's Avatar
06.30.2005, 07:48 PM
my losi never gave me and drivetrain problems except having to replace the out bearings. it was actually my fault for blowing the dirt of of them with a air compressor. oops :M:
Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
06.30.2005, 09:07 PM
For any 1:10 buggy or truck (short of running masher 2K tyres, they're very heavy) I'd recommend a Lehner Basic 5300 and MGM80 combo. Or if your in the UK a Mtroniks Genesis combo, I've had really good performance with their kit with no issues. They've apparently sold hundreds of units as well with no real problems.
My 5300 with Mtroniks esc would give me loads of runtime, and more power than I knew what to do with. 60mph on 8 cells is easy work in my T3. I use mostly GP3300 batteries with my brushless kit, they perform great, look into getting 7 cells if your charger/power supply can handle it, just make sure the pack will fit in the car OK.
So ideally in your position I would get an MGM80 controller, Lehner basic 5300 motor and 6 or 7 cell GP3300 packs. This will give you everything, more power than you can put to the ground around the street half the time. The extra cell makes a lot of difference as well.
Associated trucks are built to take a lot, mine fitted with mashers and every RPM part (even GT nylon arms at front) will happily jump over my garage (about 8ft tall) without thinking about it as long as you land on all 4 wheels.
Never heard of Tower Pro, but if your looking for a servo check this out: (if its against the rules please delete the link) http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
Good quality, fast and strong, I put one in my truck not too long ago and use it in my TC3 as well. Just check the measurements on it to be sure it'll fit in your car, its a bit longer than some servo's.
  Send a message via Yahoo to Rtsbasic
RC-Monster Mike
Site Owner
06.30.2005, 11:50 PM
I sell those servos for less, actually.
Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
07.01.2005, 05:22 AM
Just had a look at the servo's you sell, i couldn't find the specific one I linked to (BMS 631MG), but I see you do stock most of the other ones, but the ones you stock are more suited for trucks than something like an Evader.
Edit: Sorry I just found it and your price is better, bit hard to find though.
RC-Monster Mike
Site Owner
07.01.2005, 09:08 AM
Yes, I need to get a seperate section for the radio equipment, I think. I am starting to get a lot of stuff and it is difficult to keep the site looking clean.
Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
07.01.2005, 09:20 AM
Sometimes you need to add a section to get more customers :) I think the site could still look clean with a slight restructure of the sections or simply adding a radio equ section.
RC-Monster Mike
Site Owner
07.01.2005, 09:32 AM
Yeah, that is what I was referring to. I have enough stuff to justify a radio section, which would also clean up the other sections that have the radio stuff listed in them. I will try to get it done over the weekend.
captain harlock
RC-Monster Captain
captain harlock's Avatar
07.01.2005, 06:41 PM
May be a section for touring cars too?!
Nice to meet you!
rc freak
07.01.2005, 06:45 PM
Touring car what is this you speak of? lol
Got Sand?
riverat1540
riverat1540's Avatar
04.07.2007, 12:07 PM
Originally Posted by SpEEdyBL
Go with the novak. I find that this motor paired with 7 gp3300s is the limit for the evaders (stock). I've ran my novak in my evader st for about 6-8 incomplete runs in a row now, all because of braking parts, and parts coming loose. And no, I'm not a bad driver. However my evader is 3.5 years old and I usually use masher 2k tires that put the car under a lot of stress. Anyhow, your 1500 mah batteries will be the limiting factor if you buy any brushless motor. Get gp3300s. (Night and day difference between the gp3300s and my 1500mah nicds).
i do not agree. i have a maba max running a feigeo 380 6t on a 3s high discarge lipo maxamps 8000hv and my ubgaded tranny handles it fine with the proper slipper adjustment. my tranny upgrades include:
aluminum idler, associated b2 diff. make sure u get the rings and the right size bearing for it., carbide diff balls and thrust balls, and a rear towblock brace is also a must as this setup is hard on any drive train. but anyways my car flys and i have no tranny issues but never run the slipper to tight or u will strip the diff gear like right now. biggest mistake made my brushless newbies
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
