04.11.2007, 08:13 PM
Yeah, the grease adds a little stickiness (I guess that's what you would call it), but it sounded smoother when I used some. Doesn't take much. I just put a small dab on 3 spots of one of the gears and just spun the output shaft slowly until all the gears were fairly evenly coated. If you dab grease on the gears and then run it WOT, the grease will fling off onto the walls of the tranny which doesn't do much good.
