Go Back   RC-Monster Forums > RC-Monster Area > Product Reviews
ssspconcepts
ssspconcepts's Avatar
04.12.2007, 09:48 PM
Originally Posted by GorillaMaxx360
Here are my pics with the right shimming the arms work great. i will have more updated pics this weekend. but one thing is for sure you will have some shock issues with those shock towers because that is what i have and for the shocks to work good no binding you need longer screws for the shock stand offs and you need to put some shims between the tower and the standoffs becuase the arms are sligtly wider and the shock postions can be bent so aslong as you shim the towers and standoffs, arms them selfs and make that brace that chopndroptx, showed you should be fine.
BTW may i ask why you want to replace those lovely arms you have right now with the Ti ones.
I am building another truck....I guess this may be a dumb question...I can't tell by looking at the photo...
Is it possible to mount the lower shock brackets on the inside of the arm? Would that mitigate the need to shim the upper standoffs? My guess is that you tried that and the binding was worse...
