Go Back   RC-Monster Forums > RC-Monster Area > Product Reviews
ssspconcepts
ssspconcepts's Avatar
04.13.2007, 03:57 PM
Originally Posted by Serum
I think CF hingepins might be helpfull. Haven't tested it yet, need to order a set of them.
Serum,
Have you had the same trouble the others mentioned? Specifically, I am curious if you have bent lower front hinge pins with the Flex Tek A-arm setup?
CF hinge pins....hmmm. Is that CF as in carbon fiber? If so, I am not sure I can embrace the idea of using a composite for that type of application (hinge pins). I know that everywhere you look...in every industry...people are using it to achieve amazing results....but wow, sure is a lot of friction and trauma that a small pin has to suck up....
I won't doubt you if you test them and say its the way to go. I wonder if the guys at Beat Your Truck have tried them out?
