zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.14.2007, 09:25 PM
Brian, have you heard about the Segway 'concept centaur'? :eek:
I am waiting for a reply back from Lehner email... to see if it has enough 'mass' to the motor to power it(duty cycle). But seeing as it's so efficient, it should be no prob with water cooling.
I plan on using A123 batts for a 52.8volts, with 23Ah cap (16s10p). But i asked them if they knew of a higher voltage controller (Jazz Power 63v) that I could use with say ~100 volts. The whole thing should weight between 100 - 120 lbs, maybe more. I want to use maybe 8,000 watts from the 3080, again maybe more. :005:
It's a fairly simple build I think...
