Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
07.02.2005, 07:34 PM
I run a 5000kv 540 brushless motor in a T3 with sometimes 8 cells, the transmission for the T4 I believe is very similar. I've had no tranny problems, ever! Never actually even stripped a spur in this car thanks to the good slipper/solid motor plate. Even with heavy tyres like Masher 2K's I just tighten the diff up a bit and its set.
You can get a full range of alloy bits, mostly everything can be alloy really cheap. If Mike can't sort you out with what you need PM me and i'll let you know where you can pick alloy bits up for them..
