generalg
01.22.2008, 12:17 AM
Are those motors going to be enough to push the savage?
I hope so.... they are good enough for E-Savage owners from what I have read.
Serum
Serum's Avatar
01.22.2008, 02:49 AM
the savage is quite a bit heavier though.
generalg
01.22.2008, 08:45 AM
ya... so what motor is good for this setup that is reasonably priced? Fieago 9xl????? or?
generalg
01.25.2008, 12:18 PM
Anyone know if this TRUERC 8000mah pack will fit in with this conversion?
TrueRC 14.8V 4S2P 8000mAh OR should I just get the smaller 5000mah 4S pack for this conversion?
Serum
Serum's Avatar
01.25.2008, 12:34 PM
Which ones? the 10 or 15 c's? the 10 c's should fit without a problem.
I expect the 15c's to fit too. Once i've got my chassis i'll get you the dimensions on what size cells you can use.
generalg
01.25.2008, 12:41 PM
I was looking at this one.
Size
44mm x 50mm x 145mm
(1.73in x 1.96in x 5.7in)
Weight
Aprox 24oz / 680g
Discharge
Up to 80A Continuous
120A Max burst
Didn't know there was a 10 and 15.... not sure which one this pack is than.
jhautz
jhautz's Avatar
01.25.2008, 12:46 PM
That's not all that big. It'll fit no problem. I just set my TrueRC pack on the lipo plate for my kit (I havent started assembling yet) and it looks like you should have no problem at all with that.
to make it...
or break it...
Silent...But Deadly
generalg
01.25.2008, 12:50 PM
What pack is it that you have from TRUERC?
Just can't decide... 8000mah or 5000mah more weight and runtime or lighter weight and less runtime. uuuurrrrrr
jhautz
jhautz's Avatar
01.25.2008, 12:56 PM
8000mah. The 5000mah at 10c dont have the current capability. I typicially think anything with 80A or greater constant rating and 120A burst is adequete for 1/8 brushless. Less and you risk damaging the pack by putting to large of a load on it IMO.
Ive never had a 5000, but I can tell yo the 8000 are excellent value for the $. Ive had a set for a couple years now and they are still runnin strong.
to make it...
or break it...
Silent...But Deadly
generalg
01.25.2008, 01:02 PM
jhautz, thanks for the help. You just made me spend $140!
:D
Serum
Serum's Avatar
01.25.2008, 03:22 PM
And you got yourself some serious nice lipo's their old cells are capable of delivering 2800 watts in burst as a 4S2P pack.
cemetery gates
01.25.2008, 04:44 PM
I use a truerc 10c 4s2p 8000mAh lipo. I needed to use the supplied spacers to space out the TVP so I could get proper gear mesh and gear low enough. I use a neu 1515/1y/f and the lowest gearing I could fit without the motor hitting the battery was 52 spur, 18 pinion. This gives me about 38mph with the 3speed.
I was out bashing for a solid 35min. and only put back 4850mAh in to the battery. Also, the truerc 4s2p 8000mAh lipo is good for 3.425v/cell @ 124amp burst, they hold 3.525v/cell @ 100amp burst too. Not bad for $140....
Bye
Serum
Serum's Avatar
01.25.2008, 05:04 PM
You could use the flat i think?
generalg
That's awesome cemeterygates!
So is this the pack correct?
http://cgi.ebay.com/14-8V-8000mAh-Li...QQcmdZViewItem
Which after searching... searching on TRUERC I can't find the 8000mah pack today. urrrr, found it yesterday but not today go figure.
jhautz
jhautz's Avatar
01.25.2008, 06:19 PM
You could just order it direct from him at www.truerc.com
Dan is a good guy and will get you what you need.
to make it...
or break it...
Silent...But Deadly
