jfruge
05.08.2008, 11:18 PM
Originally Posted by jfruge View Post
Well I just ordered a Medusa
36x50mm 2200Kv V2 Afterburner Brushless Motor, w/Bonded Finned Heatsink.
5mm Shaft
I plan to use it on my sons 8ight buggy on 4s 5000
Fun Fun
Just an order update. Even tho it was listed as in stock. The last email i got yesterday said the order is being delayed because they need to bond the heatsink to the motor. I hope it will not take too long :) My RCPD Kit should be here Friday I think.. WooHoo!
John Fruge
Madera, CA
8ight pro buggy, RCPD Ultimate, 4s TP 5000, MM ESC , NEU 1512/3d, JR Z8800T
8ight pro buggy, RCPD Ultimate, 4s TP 5000, MM ESC , Medusa V2 36x50mm, JR Z8800T
Mister-T
05.09.2008, 06:24 AM
Man i'm seriously thinking to get one,
I can't get the motor temp lower in my 1/10 Truggy (MM 4600 kv), I 've tried lower gearing, change timing, put heatsink on the motor. Still running really hot, in fact I can't drive 2 battery in a row or the motor will probably cook itself.
highflier
Emaxx- FLM wannabe
05.09.2008, 08:09 AM
This may sound stup[ic but I was having a similar problem and I was advised to gear up not down. It seemed to help.
Is the ESC running very cool. (that is why they advised me it may be geared to low)
Highflier
Mister-T
05.09.2008, 08:12 AM
ESC is running hot as well
xcellr8n
05.09.2008, 10:14 PM
Originally Posted by TexasSP View Post
Any idea the weight on your 8T? Thanks for the review by the way.
Right at 11 lbs. I think it was 10 lbs 11 ozs. I will take some pics of my setup and some vids when I get a chance.
Tim
Maciolus
05.11.2008, 02:03 PM
I am preparing to convert HB Lightning Pro Evo buggy. I want to use MMM ESC, Medusa MR-036-060-XXXXV2-5 motor and A123 cells.
I think about lighter setup. My track is rather short. Buggy does not have to be ballistic. 10 min runtime is enough.
I want to use 6S1P A123 cells. 6 cells fit chassis nicely, are light and can be charged as one pack with my Hyperion. 1600kv motor will not need as much current as 2000kv. Around 30 k rpm was enough for me in my brushless 1/8 stadium truck. Moreover 4 pole motors like to be overgeared.
What do you think about this setup (1600kv, 6S1P A123, 31 680rpm)?
> HB L2PE + MMM + Medusa 60-1600 @ 6S A123
> HB LSP + MMM + Medusa 70-1600 @ 6S2P A123
> AE B44 + MM + Medusa 50-3300 @ 4S A123
> AE J82 + SW 5700 @ 2S LiPo
> AE TC5R + MM 6900 @ 2S LiPo
Buzzsaw46
05.11.2008, 02:48 PM
With your goal to lighten the buggy, I wonder if a 36-50 motor woundn't be enough. Since your not going for incredible top speeds, or crazy long runtimes a 6s seems overkill to me as well.
Your plan sounds fine but seems contradictory to your goal.
I have a heavy mostly alloy HPI NMT(very close in size to an 1/8scale buggy) that does close to 50mph for 10 min on a Hacker C40-8L and 4s A123's.
My Emaxx does 42MPH through grass for close to 10min on 5s A123's and MR36-50-3300v2
I think you can meet your performance goals and reduce weight even further!
Maciolus
05.11.2008, 03:23 PM
I just can't belive these motors are so good ;)
By lighter setup I mean 6S1P not 5S2P or 6S2P :)
What do you suggest? 50-3300 @ 5S or 50-2200 @ 6S
Buzzsaw46
05.11.2008, 05:35 PM
Well just to make sure I was thinking right I just did two back to back runs on my E-maxx one with the Medusa 36-50-3300 and one with my Neu 1512/2.5D both on 5s A123. The Medusa was running a 15t pinion 68t spur, the Neu on a 24t pinion and 68t spur. Both setups show 33mph on the Top speed calc @scriptasylum.com.
Data from the medusa run.
Data from the Neu run.
As for driving the Medusa felt a touch faster and maybe a bit quicker off the line, the Neu felt like it had a bit more midrange torque, better for racing?? or too much maybe?
I plan to move the Medusa to my EMT now, still on 4s(fits the truck well) and this should be a nice setup I think, and kind of what I think I would do with an 1/8 scale buggy if I was going to race at less then ballistic speeds. I'll do some more swapping around and see how the Medusa does on 4s in the truggy.
I'll post back with some data later tonight.
Need to mod my motor mount for the Medusa, might not get to it tonight.
Maciolus
05.12.2008, 07:48 AM
Thanks!
WOW! Only 9A of average amp draw.
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.12.2008, 10:48 AM
I really want one of these motors, I wish they had what I need in stock.
Thanks for the info on weight xcellr8n.
www.cubicle101.com
jfruge
05.12.2008, 11:40 AM
Anyone order a bonded heatsink version? I still have yet to get an update from them on my order.
I will send them an email today.
Thanks,
John Fruge
Madera, CA
pullinteef
pullinteef's Avatar
05.12.2008, 11:52 AM
I was waiting to get one also, but couldn't hold out any longer, so I bit the bullet and ordered a smooth can 1512/2D. Maybe I'll still pick up a 36-60-2000 in the future, but outdoor season is starting around here and I can't wait forever.
Five-oh-joe
05.12.2008, 12:02 PM
Thanks,
I did. I ordered the bonded 4800kv version since they didn't have the regular 4800 50mm version in stock. I sent them an email before it shipped requesting they not put on, or remove if they had put on, the heatsink. They did. So now I got a kickass heatsink and a fine motor.
Buzzsaw46
05.12.2008, 02:56 PM
Originally Posted by Maciolus View Post
Thanks!
No problem! This was a comparison that I was very interested in myself. I was amazed that the two motors were so closely matched. But it does appear if you want to save weight go with a high quality smaller motor with higher Kv and gear down a bit.
The only thing I still worry about is weather or not the bearings will fail early with such high RPM (45+k). I have a few hours on it though and it runs as well as it ever did
