Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Joey
The Big Cheese
Joey's Avatar
04.13.2009, 03:26 PM
Any news on if it handles 5s????????????
04.13.2009, 03:30 PM
I did run it a little bit on 5s. It arms and runs. Just don't know for how long. I didn't want to run it for too long as it was on a 1512/2d and the current would be rather high.
04.13.2009, 05:18 PM
Has anyone tried this with a sensored motor yet?
timaneli
08.26.2009, 07:46 AM
i tried mine with a novak hv 5.5n for 2 months on a e-revo and works great.
motor didn´t pass 55 degrees and esc never pass 45 degrees even and the end of 20 or 30 minutes running ..
regards
you are what you race!!
Joey
The Big Cheese
Joey's Avatar
04.14.2009, 12:19 AM
Wouldnt the current be lower on 5S than 4S?
04.13.2009, 05:22 PM
Sensored? What's that?
04.14.2009, 12:24 AM
Not if the gearing and the motor is the same. A=V/R. If voltage goes up, and resistance stays the same, current will go up. I'd have to drop gearing and/or use a lower kv motor (increasing R) to reduce current.
himalaya
himalaya's Avatar
04.14.2009, 01:47 AM
Not if the gearing and the motor is the same. A=V/R. If voltage goes up, and resistance stays the same, current will go up. I'd have to drop gearing and/or use a lower kv motor (reducing R) to reduce current.
Guess you were trying to say (increasing R & inductance) to reduce current.
....What a Blue Sky....
Joey
The Big Cheese
Joey's Avatar
04.14.2009, 06:59 PM
But Power = current X voltage ---- P=IV
So to produce the same power with higher voltage, current drops. In effect this equation is more direct to the VI relationship than I = V/R isnt it?
littlegiant
04.14.2009, 07:55 PM
If u are running on 5S without changing your gearing, your truck will be running faster. Which means that the power is higher. P=IV and so your current will definitely be higher.
In order for your 5S to have a lower current than a 4S, it should be geared to your current 4S speeds. If your 5S is running at a higher speed, you are just running your motor at a higher wattage.
04.14.2009, 09:46 AM
lol, yeah, I meant increasing R...original post edited.
I have an excuse: it was late and I was tired.
Cain
05.08.2009, 09:40 PM
Has anyone taken a look at the speedpassion ESC internals and compared it to this one? Have heard that they are basically the same.
lutach
lutach's Avatar
05.09.2009, 07:59 AM
They are the same.
Cain
05.09.2009, 09:46 AM
got a link to this discussion?
lutach
lutach's Avatar
05.09.2009, 10:16 AM
There's no link, it's just the facts. You can also ask Hobbywing who's a member of RCM.
