MetalMan
MetalMan's Avatar
02.21.2006, 09:25 AM
It is pretty much the 9L, but with a cool finned case (for better heat dissipation) and a removable rear endbell (no worries about it popping off).
kmracer66
kmracer66's Avatar
02.21.2006, 11:26 AM
now its between the 9l "c" and xl. opinions?
FT18T - stock
REVO - P2's, Red Rods, 40wt, Green/Tan, MX3. one day, it will be brushless. :028:
coolhandcountry
coolhandcountry's Avatar
02.21.2006, 02:32 PM
I like the xl motor better than the L motors for a monster truck.
Peace!
Country
Help support the
Rc-Monster
Buy here
kmracer66
kmracer66's Avatar
02.21.2006, 06:32 PM
cool.
so a 9xl on 16 with the 9920 would be good?
FT18T - stock
MetalMan
MetalMan's Avatar
02.21.2006, 06:52 PM
That would be an excellent setup!
coolhandcountry
02.21.2006, 10:19 PM
I have had great luck with that setup. It runs cool with good run times as well.
Peace!
Country
Help support the
Rc-Monster
Buy here
kmracer66
kmracer66's Avatar
02.22.2006, 12:02 AM
i think ill do that then. sounds good. now, Feirgao or BK Wanderer?
FT18T - stock
MetalMan
MetalMan's Avatar
02.22.2006, 12:13 AM
Blue is cooler than purple :).
kmracer66
kmracer66's Avatar
02.22.2006, 12:29 AM
sounds like a deal to me ;)
FT18T - stock
ttrmike
got truck
ttrmike's Avatar
04.13.2006, 06:51 PM
Hey dafni do you have any more pics of your truck with the lst tires on it? Do you think it could be possible to put those lst tires on a 40 series rim without cutting them?
Dafni
Dafni's Avatar
04.14.2006, 03:39 PM
I think LST tires on 40s will be pretty tight. I use mine on TwinForce wheels.
Here are some wheel dimensions (diameter x width) :
Maxx: 87 x 56mm
40s: 102 x 86mm
LST: 87 x 77mm
The LST tires fit on standard Maxx wheels no problem, but it makes the tire more narrow. That's why I used the TF wheels in the end, they are a bit wider.
Pics? Not really any new ones. Here are the only 3 I have here.
Rene has some acion shots and even some short vids from my vacation in Holland. Maybe he can upload some?
rhylsadar
rhylsadar's Avatar
04.20.2006, 07:45 AM
daniel how much is the difference in ground clearance between the nitro chassis and the g2r chassis in the middle under the gear box. given: same tires, same springs etc.
is there a difference at all?
bye
rhylsadar
______________________
Exercitatio artem paravit
rhylsadar at youtube
Dafni
Dafni's Avatar
04.20.2006, 08:47 AM
I will check tonight!
The lowest point, in both versions, is the front skidplate, by the way.
But If you want, I can check at the center tonight.
Later
DAF
rhylsadar
rhylsadar's Avatar
04.20.2006, 08:52 AM
hi
yes i see the lowest point. i am interested in the center height.
thx.
rhylsadar
Dafni
Dafni's Avatar
04.20.2006, 09:28 AM
PM sent!
