cemetery gates
01.25.2008, 04:44 PM
I use a truerc 10c 4s2p 8000mAh lipo. I needed to use the supplied spacers to space out the TVP so I could get proper gear mesh and gear low enough. I use a neu 1515/1y/f and the lowest gearing I could fit without the motor hitting the battery was 52 spur, 18 pinion. This gives me about 38mph with the 3speed.
I was out bashing for a solid 35min. and only put back 4850mAh in to the battery. Also, the truerc 4s2p 8000mAh lipo is good for 3.425v/cell @ 124amp burst, they hold 3.525v/cell @ 100amp burst too. Not bad for $140....
Bye
Serum
Serum's Avatar
01.25.2008, 05:04 PM
You could use the flat i think?
generalg
That's awesome cemeterygates!
So is this the pack correct?
http://cgi.ebay.com/14-8V-8000mAh-Li...QQcmdZViewItem
Which after searching... searching on TRUERC I can't find the 8000mah pack today. urrrr, found it yesterday but not today go figure.
Serum
Serum's Avatar
01.25.2008, 05:05 PM
Jep, basejumpers, that's Dan from truerc.
generalg
01.25.2008, 05:08 PM
Jep, basejumpers???
jhautz
jhautz's Avatar
01.25.2008, 06:19 PM
You could just order it direct from him at www.truerc.com
Dan is a good guy and will get you what you need.
to make it...
or break it...
Silent...But Deadly
