08.30.2008, 08:50 AM
My v2 MMM arrived on yesterday, was promptly installed. i love it, very smooth at low speeds, tonns of torque, i only ran it for 5 mins and it ripped up a cvd :D
08.30.2008, 11:58 AM
I almost had an episode...
In fear of my bad cell, i set my lipo cutoff to 16.4v, i jammed the throttle once and the esc hit the cutoff (pack was 3/4 drained) so i checked the pack- all the cells held up fine. the esc registers on ccl, but it cuts off when i arm it... is it toast?
08.30.2008, 12:09 PM
it died... :( no smokke, castle link still works, no broken connections, full story in the CC section....
08.30.2008, 02:33 PM
WHOAAA BREAKING DEVELOPMENTS!!!
Hey, anyone outther with a MMM, unplug all connections for motor and batt, plug a rx pack into your rx, and pull the trigger, it spinns the fan variably
well i tried that, now i plugged in all connections with the motor and batts and it works!!!!! Flawlessly, so im using an rx pack now i gues :D
08.30.2008, 02:38 PM
That's good news! :)
I guess the BEC in the MMM isn't really all it's cracked out to be...
08.30.2008, 03:20 PM
i lied... i put it back in the truck and it let the genie out... :(
08.31.2008, 01:05 PM
08.31.2008, 01:51 PM
That's a GREAT deal! Is there a way you can find out (for me) if JR and Hitec RX's work with the M8?  Also, if you find any more great deals on M8's or M11's lemme know!
08.31.2008, 02:04 PM
m11 are expensive as Hell, and any rx will work as long as its the same frequency. the only problem i see that the rx that comes with it has "s" connectors where the power and signal wires are flipped- might use my current rx
08.31.2008, 03:52 PM
Actually, my XR3 wouldn't work with Airtronics RX's.
09.08.2008, 05:50 PM
Be careful I am 99% positive you cannot use any reciever with the Airtronics transmitter. Remember there is positive and negative shift rx's and not all are compatible.
08.31.2008, 05:34 PM
Genie only came out because you were rubbing on the esc too much man...
WARNING: May become violent.
09.01.2008, 12:01 AM
Looks like you finally got a good radio.  Im thinking about the dx3r or a 3pk SE but I dont know if I need anything that advanced right now...
RIP- Tammy (9/14/08)
Dsm needed
09.01.2008, 04:23 AM
im getting a Dx3 here one of these days
09.01.2008, 09:52 AM
Thanks guys, i just wan something that can be adjusted ;)
