its me
There is no help for me... I'm addicted to R/C
its me's Avatar
01.06.2009, 03:11 AM
man that thing looks awesome. Are you able to run tall gearing? Take advantage of that extra torque!
Hahaha funny you said that, the gearing right now should be about 75MPH but im diffing out really hardcore.. I got 7K in the center :)
I was just bliping the throttle, thinking about running 22t pinions.
rccna.com
its me
its me's Avatar
01.06.2009, 03:14 AM
Nice video. Glad to see it finally running .
thanks man!
Nice to see your rig finally up and running. That setup looks sweet. It also seems to be running pretty smooth for you. How is the drivetrain holding up for you? And you need to get yourself a set of Axial beadlocks for that thing. There is no way that CA glued tires are going to hold together with all of that power. Check out the thread "To Glue or not to glue". Nice work itsme. I am sure that you are feeling much better about your work now.
haha thanks! its holding up well so far!
rccna.com
01.06.2009, 10:31 AM
Thicken up that center! Get the thickest you can get, a "locker" lube if you can. Oh, and more video
SnoopMaxx
SnoopMaxx's Avatar
01.06.2009, 05:48 PM
Awesome.. I love when he says "That was coooaall "
Morten SnoopMaxx
Never to old to play
c",)
Emaxx_Quebec
Emaxx_Quebec's Avatar
02.03.2009, 11:17 AM
What is the best to use to be closest to stock maxx diff
  1. Raminator
  2. Aftershock
  3. LST
  4. LST2
  5. Mayhem
What the gear ratio of those diffs?
Thanks
02.03.2009, 12:08 PM
  1. Raminator
  2. Aftershock
  3. LST
  4. LST2
  5. Mayhem
Thanks
1st 4 you listed are all the same, 13/43 ratio. Not sure about the mayhem.
Emaxx_Quebec
02.03.2009, 12:13 PM
Thanks
So the only diference is the case. ( plastic vs silver alu vs blue alu)
Emaxx_Quebec
02.08.2009, 01:01 PM
question about the lst 2 diff convertion
do my traxxas driveshaft and center cvd can be use whit this convertion
a got a 3905 maxx
You'll need to purchase the adapters mike sells, here
. those will go in place of the normal outputs for the left and right. so if you replace both diffs you'll need 4 of those units.
So Ok for the 4 corners.
BUT for the center??
I use
Can I bore ( drill) them out to 8mm.
Or do I need something else like 2 of
If so, how do i connect them to the CVD.
Thanks.
SnoopMaxx
SnoopMaxx's Avatar
02.09.2009, 01:44 PM
You need a set of these 1/8 diff output shaft
Use these 6mm output shafts to replace the stock output shaft/drive cup on most 1/8 diffs. Allows use of stock driveshafts for Maxx and Revo trucks while using 1/8 diffs. 2 required per differential.
You can also make them from Revo spindles
Morten SnoopMaxx
c",)
Emaxx_Quebec
02.09.2009, 02:33 PM
Yes, i know but my Q is for the center shaft.
The one that goes from 8mm diff pinion output to trans.
02.09.2009, 03:32 PM
Yes, you can drill out the stock part to 8mm to fit the diff shaft- seen it done a couple times. You cant use Mikes part with cvds, you'd have to use dogbones with different drive cups that he sells (8mm bore), or possible drill out the cvd to 8mm, but that might weaken it too much.
Emaxx_Quebec
02.09.2009, 03:55 PM
Thanks Neil, that's what I was thinking.
I'll go with Traxxas CVD drilled to 8mm.çà
We'll see if it hold up.
its me
its me's Avatar
02.17.2009, 04:35 AM
Just when I got this thing all tricked out, added mechanical brakes/ redid the suspension/ the dam MMM go's poope :( when I flip the switch only one of then turn on.... guess i need to send them back to castle.. they were V-1's
pics will come soon.
rccna.com
02.17.2009, 01:50 PM
Mechanical brakes! Nice. Definitely get v3's and post pics, you build some really nice rides, I like all your youtube stuff.
Tarill the Mad
03.02.2009, 03:44 PM
I'm posing this question to the 2 people who posted pics of their projects. I was wondering what you used for the center diff. The mount, diff, top plate, and is that a t-maxx motor mount on the center diff? I am new to the forum and just getting back into rc and saw that this thread is based on an idea I had been thinking about before finding this forum. Thanks for any answers and sorry for length on message.
