crazyjr
crazyjr's Avatar
09.03.2005, 12:30 AM
I was looking at the overall length of the ezilla against a savage and it's 4" shorter(17" against 21" respectively)so you may need a smaller, less torquey setup like maybe an 8L or even a 10 or 12S (not sure of weight but probably lighter than an emaxx)but there are differences between the ezilla and savages
coolhandcountry
coolhandcountry's Avatar
09.03.2005, 10:24 AM
Yep that is kind of short. Is it narrower to. That would be a difference as well. Have to let us know on the test run. Maybe the savage guys can get the tranny out of it for there brushless conversions.
Peace!
Country
Help support the
Rc-Monster
Buy here
elite3ge
09.03.2005, 11:24 AM
should i take er to the track today :)???
coolhandcountry
09.03.2005, 12:40 PM
How does it do? Handle good? Drive good? Let us know. Curious RCers want to know. :)
Peace!
Country
Help support the
Rc-Monster
Buy here
Nick
COOKIES!
Nick's Avatar
09.03.2005, 12:43 PM
Why Boeties on only one side of the truck?
~ Nick.
Serum
Serum's Avatar
09.03.2005, 06:28 PM
The other tires are on the background..
Looks like a short wheelbase.. Is that an Audi in the garage?
elite3ge
09.03.2005, 07:10 PM
i was trying out some tires thats all, those are maxx bow ties, they seemed better fit then the response tires and some others, just testing.....
inddeeeeeddd thats an audi, good catch :)
had it at the track today, short wheelbase turns on a dime and as much as it looks like its about to tip over like a savage looks it handles pretty good stock!
I cant wait to try my cheap 3300s i got, stock is 2000 nicad - ill report when I get them but its quick enough for the track i run.....still want a BL system, waiting on the mamba maxx! :)
BL_Force
09.06.2005, 12:51 PM
It will be interesting to see how durable the driveline is with brushless.
elite3ge
09.07.2005, 10:09 PM
ok whats the cheapest way to get a BL in this bad boy...
It doesnt have to be a total rocket, just like 70mph, thats all....JK.
I dont even know where to start aside the hv-maxx.....which I dont think I want...and the mamba-maxx is to far out :) so what can I do on a budget...
I think ill stick to running twin 6cell stick packs in the stock locations......although I keep thinking I should run like 8-10 and save weight cause there comes a point where Im adding weight for more voltage but i dont know how worth it it is.....either way im not running 1000000 cells so with 12 possibly 14 and or less what do you recommend???
BL NEWB for sure here :)
BL_Force
09.08.2005, 04:53 PM
A Feigao 9L or 10L with a Warrior 9920 is pretty much standard fare for a MT of that size. You will find any weak points in the driveline real quick though. lol
starscream
RC-Monster TQ
starscream's Avatar
09.08.2005, 06:27 PM
Looks good
How much does the e-zilla weigh rtr?
Can you fit more than 12 cells on the truck?
Ha Ha
The Flashlight Strikes Again...
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
09.08.2005, 06:34 PM
Most likely not. A setup with a 9l would need more then just 12 cells. Woudl 8L be a good setup for 12 cells?
elite3ge
09.08.2005, 06:36 PM
i can cut out the battery tray a tiny and I could easy mod 7 cells on each side but honestly...
I dont want to blow drive parts all the time I just want it a little faster and longer run times if it were to be a little more efficent with BL.....
I dont need best...i need used and cheap but in good condition :) perhaps a hvmaxx? I dont know....im to new to electric and BL lol
starscream
RC-Monster TQ
starscream's Avatar
09.08.2005, 07:40 PM
Ah, the age old question... what BL motor to run? The answer to this question relies on your specific needs, requirements and personal preference.
I guess your budget would fall under requirements :)
What are you planning on using the truck for? bashing, racing, both...
How much run time do you require?
If you are racing, the runtime will most likely be less than if you are bashing because of the hard acceleration and constant throttle used in a race.
If you want a longer runtime you either need to use batteries with higher mAh rating (which = more weight) or run a system with higher voltage for increased efficiency (wich also = more weight).
It is my preference to run a higher voltage system because I feel it gives me more bang for my buck due to the increased efficiency. I ususally run ~20volts. I also race against the nitro trucks which have 12-15 minute Mains.
I think that if you can fit 14 cells on the truck, the 9L and the 9920 (from Mike) will work well. You'll probably need to adjust the gearing a touch regardless of the system you choose. Proper gear reduction is important to maximize the motor output and keep temperatures down.
Hope this helps
What size and pitch are the pinion gears?
The specs say that the e-zilla is 9.5lb rtr, is this correct?
Ha Ha
elite3ge
09.08.2005, 08:54 PM
I guess if it says 9.5 thats prob on par....it seems light without batteries, but ya ....with batteries installed I guess thats about right.
I just want it faster then stock, I mean 50mph would be cool but again its not realistic, and prob not necessary either. I would assume Ill run 3000s, or 3300s (sport packs for now) and 12-14 cells......
Gearing - 66T spur and 20T pinion is what I think is stock - ratio being 16.75 : 1
