fromdaboz707
05.16.2008, 01:26 AM
Originally Posted by ogrfre01 View Post
I am just in the making of another conversion. I got a MBX5-roller for a really nice price.
I just finished the batteryholder ( i was about to order one from Mike but it was out of stock) Then i tried to make one myself..... its not that bad really.
This is how far i´ve come so far:
Close up with handmade tray:
I am making a mount for the esc and bec soon.... then it is ready to race.....
what did you make the battery holder out of?
ogrfre01
05.20.2008, 07:01 AM
Hi, i made the tray out of a plastic cutting board that was 13mm thick. Works great. I have now tested the car, it runs great.
On monday i will finally try it out on a track..... the summer is late this year to the norhtern part of Sweden and no tracks are open nearby untill monday..... then it is time to really put the E-MBX5 to the test!
I have a Monster Max order pending from Mike...... I will also buy a new motor, but have not decided if i shold go for a 1512 2d/f or a 1512 2.5d/f..... time will tell....
Romster
05.20.2008, 10:56 AM
Nice ride and nice job!
Back to the drawingboard
ogrfre01
Back to the drawingboard - 05.27.2008, 03:21 AM
I just put my E-MBX5 to the test... it ran very nice, no heat issues, app 22-25 minutes of runtime. However, efter some testing i was about to clean the car..... the i saw this:
The batterytray broke..... not a big deal, i went to the garage and started on fixing a new tray....
Started with drawing it up:
After some cutting drilling etc all part looked like this:
Would it fit?
Perfect!
Now its just to put som velcro, straps and maybe some stickers on it and im ready to go..... no additional holes where made i only used the ones that was on the chassie originally
ogrfre01
06.09.2008, 10:22 AM
I have to do something as i am waiting for the MBX6 to arrive.... so what can i do......
I just put some Big Bore shocks on my Mugen, it went ok. Not a perfect fit but close. I hade to shim the upper mounts abount 2mm and use some force on the lower mounts.... but finally i got them to fit
Front:
Back:
Car (Dirty.....):
No body:
Its raining so i havnt tried it yet.... as soon as it stops a may go to track and try it out!
cmcclive
06.09.2008, 11:24 AM
I am worried about your new battery tray...
I managed to snap a piece of welded aluminum on my battery tray. I am concerned that all 4 sides are just folded up, perhaps you could epoxy/jb weld them together? (I am just thinking a closed box would be stronger). Perhaps I am overly cautious, but that looks like a heavy battery... if the outside wall of the box bends down that is would be a large dangerous flying object.
rchippie
rchippie's Avatar
06.09.2008, 12:40 PM
Kydex would would work great for your tray . Ask around from people here who have used it. Mikes tray works very well also & it a good price for what you get .
REAL MEN RUN BRUSHLESS
06.09.2008, 12:50 PM
The only trouble I've seen with the folded aluminum trays is that if you get any stress cracking at the bend, that joint is weakened and can be prone to snapping.
Also, different types of aluminum are better than others. For workability, I usually use 6061-T6 from onlinemetals.com. Thicknesses around 1.5mm (~1/16") work well. I tried some 6061-T6 from Tower and it stress cracked badly no matter what I did, so I'd stay away from that stuff.
Right before bending, I usually heat up the metal to over 200*F. The bend seems to be less prone to cracking. It also helps to increase the bend radius a little. So, instead of a really sharp 90* corner, it's more like a 90* small arc. Since I use a vice and hammer to do my bending, I cut a piece of steel and rounded off the edge as the "bending plate". This makes the aluminum bend a little more gently.
cmcclive
06.09.2008, 01:00 PM
Mike got my order this morning for two custom trays. Once they come in I have a small amount of modifications to do to the mudgaurds and they should fit better then my homemade ones (and hopefully more druable).
ogrfre01
06.09.2008, 01:13 PM
I have raced with that tray several times now, never had a problem with it, before this one i had one made in plastic, it broke instantly..... I am not worried at all for my tray, both my 4S Polyquest batteries are about 500 grams....
I will get one from Mike but not right now, the shipping cost is allmost the same as the tray so i´ll wait untill i get some more stuff to order......
Right now i´m just waiting for the rain to stop but i will probably have to wait some time before i get to try my new shocks :(
TDC57
TDC57's Avatar
06.09.2008, 04:03 PM
That's a great project you have going there, I'm happy for you its' complete and running, those big bore shocks look great!! ( I bet it handles much better now).. Where do you live that the shipping is the same at the cost of the tray??
Regardless. Great conversion, well done!..
Nothing!.. Hahahahaaa..
ogrfre01
06.10.2008, 12:06 AM
Thanks for the kind words, i live in Sweden (Not Schweiz ). The little i have tried, it seems to be smother with the new shocks, but i wount know for sure untill i can try it on a track..... bummer, it is still raining... last week we had +25 (centigrade) every day.... and now... only rain and allot colder (about +15). What kind of summer is this
