blueb8llz
05.02.2008, 02:20 AM
ive heard of ppl using epoxy, is that the same thing as superglue?
Serum
Serum's Avatar
05.02.2008, 02:43 AM
Check your driveshafts; they tend to bind against the shocks because they are too fat. check to see if you can see if they are damaged: scratched all around is what they usually do.
About the bulk; you can drill the hole a bit deeper (or through) with an 2.5 mm drill, and put a longer screw in it.
blueb8llz
05.02.2008, 04:51 AM
yea for sure its not the driveshaft rubbing on the shocks. i dunno bout the drilling the hole, i think that would make the bulk very weak. i think using the super glue would be better.
blueb8llz
05.02.2008, 04:41 PM
no actually nothing spins...everything locks up, but im still able to hear that stretching noise. but it sounds like it has to stretch cus im like trying to force it to spin but its not letting me. by the way, im not like really forcing it to spin, or that will just ruin my diffs. im just giving it the tension and thats when i hear that streching noise.
and now im skeptical bout using that glue because what if one day my bulks do break , will i have problem removing that screw?
Patrick
Patrick's Avatar
05.03.2008, 12:15 AM
Twist in the driveshafts? Diff case moving in the bulks? I'm not really sure, I haven't heard noises like that in my cars.
blueb8llz
05.03.2008, 02:41 AM
nope its none of those. i ll wait till something breaks so i know exactly what to fix then haha. for now, i may jus do the ca glue in the thread and screw it in
Desmo
05.04.2008, 12:47 AM
It will still come out when you want it too. The glue won't stick to the screw that bad. You can normally just unscrew it. Are you sure the diff doesn't move in the bulkheads? Try a drop or 2 of water where the diff fits in the bulk heads then see if the sound is gone.
