who thinks they know what this wierd sound is?
blueb8llz
who thinks they know what this wierd sound is? - 04.30.2008, 06:37 PM
this is on a 3905 emaxx. it mades a wierd noise everytime i accelerate. the noise sounds like a old door or floor creaking or like something stretching, or dead leaves being stepped on. odd thing is, it only makes the sound:
- when you go forward. reverse doesnt make sound
- when i lift up the truck and accelerate, no sound
- when i lift up my truck and compress my springs to mimic as though the truck is on the ground, no sound
- when i roll the truck forward with my hands when its on the ground, it doesnt make that noise either.
you only hear the sound in the beginning of the acceleration, as soon as the truck goes , the sound stops
its not a grinding noise so i doubt its the gears from the diffs or gearbox.
and the sound is coming from the rear of the truck positively.
heres a a sound bit no video sorry:
http://home.earthlink.net/~webhost/traxxas/emaxx.mp3
picture what i was doing with the emaxx...mic stand holding a nice 3/4" diaphragm condenser about 1' off the floor, down slightly from horizontal. emaxx backs up to the mic and i jerk the trigger and repeat
83gt
04.30.2008, 06:41 PM
I think it's a combination of drivetrain slop and the slipper slipping.
brushlessboy16
brushlessboy16's Avatar
04.30.2008, 06:43 PM
yep jason's got it, sounds like the slipper.. or maybe a bad bearing that rattles when its under load
Takedown
WARNING: May become violent.
Takedown's Avatar
04.30.2008, 06:48 PM
Ive heard numerous complaints like this from the new e-maxx... Theirs a vid on youtube somewere about one of them.
RIP- Tammy (9/14/08)
blueb8llz
my slipper is like one full turn from being the tightest already. its still a fairly new truck. it didnt do this untill like a week ago. i cleaned out the bearings on the out and inside of every wheel. very funny thing is also if its a bad slipper would it do this:
i place my truck on my lap. the front of the truck is facing away from me. i squeeze the left and right front tires with my thighs so that both front wheels dont move. then i turn both the back left and back right tires with both my hands in the same direction, this is when itll make that noise...creaky noise or whatever the sound.
i turn my truck around and do the same thing and turn the front two wheels this time, and same thing, i hear the noise in the rear.
DrKnow65
DrKnow65's Avatar
04.30.2008, 07:39 PM
gear noise from the center diff? is the center diff limited slip?
blueb8llz
04.30.2008, 07:45 PM
the noise is coming from the rear. maybe the rear diffs. but anohter person from another forum has the exact same problem and he opened and checked his diffs. everything was fine in there.
Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
04.30.2008, 08:32 PM
Did you try tightening your slipper up to the tightest it can go? Then see if the noise is still there. JMO.
NECESSITY IS THE MOTHER OF INVENTION
Emaxx Tranny slipper modification (Strobe like)
http://www.rc-monster.com/forum/showthread.php?t=9341
bdebde
That's All Folks!
bdebde's Avatar
04.30.2008, 09:05 PM
I have had a bad sounding diff that looked fine, but I replaced it with a new one and no more problem. The plastic diff cup could be stretched or stressed enough to let the gears slip.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
04.30.2008, 09:09 PM
I would guess it's a bad diff. Thats why it only makes the noise under load and in reverse the load is on the front diff.
blueb8llz
05.01.2008, 01:17 AM
i think you guys are right about the diff. thats where i think i hear where the sound is coming from. but how did my diff already blow after one month? i dont even have brushless yet. is it because i have my slipper too tight? i love doing wheelies thats why i have it so tight. but someone told me you can have it very tight even like 1/4 turn to the tightest and itll be ok. and im sure you guys with brushless setups have waaay more torque than i do and can do wheelies at will and prolly have no diff probs.
so how did it cause this so i know how to fix it? and lastly, what if i dont fix the problem, can it ruin more things later? because my truck still runs perfectly fine other than just hearing that sound. should i just wait till it blows then replace it, just incase its not even the diffs?
oh hey i made this post in other forums, feel free to check what they said maybe that would help out. sorry, this noise is buggin the ish outta me..need all the brains i can get.
http://www.rcuniverse.com/forum/m_74...tm.htm#7442599
http://radiocontrolzone.com/showthread.php?t=248060
http://monster.traxxas.com/showthread.php?t=416312
Fast5sRevo88
05.01.2008, 12:34 PM
It kinda sounds like they forgot to put grease in the tranny at the factory.
blueb8llz
05.01.2008, 06:15 PM
ok, im almost sure i know what the prob is. one of the guys that had the same problem replaced his rear bulks and the noise is now gone! reason for replacing was because the screws from the skid plate going onto the bulkhead was stripped.
and last night while examining my truck again, i titened all the screws on the rear of the truck and i did notice that i had one screw stripped exactly where the skidplate goes onto the bulkhead. i tried many screws but still wouldnt get tight. i really hope that this was the problem.
hey guys, is it bad if i didnt replace that bulkhead? its only one screw should i wait till it gets worse..whats the worst that can happen. i sorta dont feel like changing it just yet since i think its just a stripped screw.
thanks
bdebde
That's All Folks!
bdebde's Avatar
05.02.2008, 12:42 AM
put a couple drops of superglue in the hole and put the screw in.
blueb8llz
05.02.2008, 02:20 AM
ive heard of ppl using epoxy, is that the same thing as superglue?
