Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Backfire
06.12.2008, 06:31 PM
TDC57,
I checked on that part number for the 808 Active Diff outdrives, it is 355161 for the pair. You would need that and the 355143 gear if you want to convert the original 355100 Active diff to work with the 808.
Bryan
TDC57
TDC57's Avatar
06.13.2008, 12:43 AM
Originally Posted by Backfire View Post
I was looking through your original list of options parts, and noticed one item you should update. The 355100 Active Diff is for the original XB8 to the EC, but not for the 808. The part number you want for the 808 Active Diff is 355102. This system will include the correct 43T ring gear and shorter outdrives for the 808. You could convert ta 355100 to work with the 808, but you will need the 355143 ring gear and 808 specific Active Diff outdrives (I will have to get the part number at work tomorrow). The cost of those pieces would not make a conversion justifiable, unless you have an Active Diff already.
The 352303 and 353303 offer some added adjustability to the suspension, but if you are just starting out, you may want to leave the stock pieces until you get comfortable with the car and are ready to tweak the setup to your driving. The optional plates do look fantastic, and they are a bit easier to deal with when you want to service the diffs. If you install them, you may just want to start with the equivalent to stock geometry unless you feel the setup needs some work. The same holds true for the steering plate, 252573. The stock plate is quite durable, so your main benefit would be to fine tune the aggressiveness of the steering. XRAY tried to simplify the stock pieces so that the setup was not overwhelming to most users. Durability of the stock parts is great, as many have commented on, and most of the options add some added tuning benefit(hinge pin holders, chassis braces, etc.). Having said that, man do the aluminum caster blocks look trick! I didn't plan to use them for mine, but after seeing the press release photos for them, I may have to get a set just for appearance! They are one of the coolest 'looking' options XRAY had produced!
As many 808 drivers have shared with us, only a couple of spring sets and oil weights to adjust the shock and diff package is all that is necessary to get the car close for most drivers and track conditions. Tires and the shock package are probably the most critical "option" pieces to get your car dialed in. When you start to fine tune the setup, these option pieces give you an added range of adjustment. I am a sucker for options, so I will probably add many of those same pieces to my conversion too, but my 808 is a much better car than I am a driver in its stock form!
Bryan
Hay Bachfire..
Thanks so much for the information. I’ll send out an email to the supplier and ensure that I get the proper parts.. (Thanks!!!)..
I saw the same Alum caster blocks (they do look trick!!) they are 39.99 each, but none are in stock. (I checked!)..
I understand what you saying about the Alum parts and appreciate the advise, I actually received them today and drove my 808 at the track for a good hour. I was extremely impressed with the 808 durability and it performance is outstanding, it goes rite where you point it.
So now I'm left with the dilemma, do open my nice new shinny bling parts and install them or do I first get used to my buggy, learn it’s limits and then start to improve on them and my driving skills???? (TBD)..
Thanks for your time Bryan.
Have a great one..
Shaun.
Nothing!.. Hahahahaaa..
TDC57
TDC57's Avatar
06.13.2008, 12:46 AM
Originally Posted by pumpkinfish View Post
Just saw this thread. Wow you really didn't need all those hop-ups. My 777 needed them. In my experience, the aluminum chassis braces are too stiff unless you are on an indoor clay track. Keep the aluminum towers and ackerman plate as backups. The only hop-ups I put on mine were the carbon fiber center diff plate and carbon fiber front upper brace (steering brace). Oh yea I forgot that I put on the Losi lexan rear arm "mud flaps"...lol!
The one thing I highly recommend to all 808 owners is switching out the sway bars; they are way too stiff in my opinion. I went with 2.2 front and 2.4 rear and it feels awesome now.
Enjoy it as it is a really fun buggy to drive!
What's up Pumpkinfish (like the name!).
Yea I know, I know I don’t need all of those hop-ups parts, like many guys don’t need the blue pill either but they get it!..
As luck would have it the track that I'm running it at is a indoor clay track so see some of that bling will actually help.. . I actually haven’t decided to take apart my perfectly good running / driving buggy “to weigh it down & pretty it up” but if do that get that wild hair up my a$$ them I'm at least prepared for it..
I am going to order the referenced sway bars above (thanks for the tip ) and I'm going with one size heavy spring (light blue??) the reason being the bottom kept hitting the ground every time it landed off any size jump. We’ll see..
Thanks for the comments PF and have a great one..
Shaun.
TDC57
TDC57's Avatar
06.13.2008, 12:48 AM
Today was a green light day at my house, look what the mail brought me.
My Neu 1512 2.Ds
My long sought after “Bling” for my 808 (I'm still some parts missing) but I received about 80% of the overall order.
My E-Bay find!, I’ve got front & rear suspension and drive train along with all steering components. Now I can just about break anything on my 808 and I’ll have a replacement part for it… (Yes!).. some parts missing from photo, box 2, tomorrow?.
Thanks for your time and have a great day.
Shaun.
pumpkinfish
06.13.2008, 09:07 AM
Shaun.
Shaun,
If you are bottoming out try changing the pack of your shocks first. What setup did you use? If you go to RCTech, Rocco a factory Xray driver can give you some great pointers on the 808. Fortunately for me, he posted a starting setup for his local track which matches my local track description.
One thing I can say about the 808 is that is very sensitive to changes. I was practicing last night and played with a few things. Every time I made a change, it was very noticeable on the track the very next lap. I lowered the rear inner camber link to the lowest hole and wow was it a completely different car. I also put a thicker rear diff fluid in and the car was almost undriveable. I think for this car going with anything in the range of 1k-2k is the ticket. I am still playing with the front and center diff fluids. Also, I raised my ride height slightly and it was drastic. I found at my track that a high ride height is not a good a thing. I would set the ride height no higher than arms level and even that might be too high.
-John
TDC57
TDC57's Avatar
06.15.2008, 04:22 AM
Hay John..
I'm using the “recommended” 1.5 in the front and 1.3 in the rears, rebound set at 50% on both front and rear shocks, oil is 600cST in the front and 350cST in the rear, this is the oil that came in the kit. My gut says put in 50 in the fronts and 40 in the rears?? But for now this I’ve got.
It’s interesting with what your saying regarding diff oils, I’ve read several of the x-ray threads, asked around and decided on originally going with the 7000 in the fronts and 3000 in the rear, most of the threads are recommending a 5k & 5k approach, but yet you’ve had luck with a 1k – 2k??, I was going to redo them with 5k&5k but should I now consider 2k-1k as another option??. I'm running a track that’s clay, the average lap time is 28sec, I’ve got a 1512 2d, mgm 12012 and PQ 4s 30C 4500mAH, I’ll be turning some rpm’s so don’t I want / need thicker oil?.
The height is another tec issue I'm actually looking forward to learning about, believe it or not I'm actually look at picking up a Hudy 1/8th off-road set-up system with droop blocks, gauges, set-up board, etc. I'm thinking that all of this crap should get me setup correctly!!. And now that I’ve got the XB8 I’ve got two buggy’s that I can useon it. Yeah that helps me justify the new purchase / not to feel guilty
I'm planning on striping this thing down in about two month 10 /15 days at the track (if it last that long without breaking?), to check everything, change oils, and others goodies But until that happens I was thinking of going up one size on the springs and changing oil weights, maybe going to a 1.4 in the front and keeping a 1.3 in the rear?? To many dam things to things to thing about.. Maybe I should just concentrate on my driving for now..
Have a great weekend John and thanks so much for your time.
Shaun.
TDC57
TDC57's Avatar
06.15.2008, 04:24 AM
We’ll some more parts came today (yes!) My remaining suspension, rear wing and complete replacement screws.
I also received my new bad boy Lipo’s…. (2) PolyQuest enerland 30C 4500mAH. I'm really stocked about these lipo’s I'm hoping that the 30C will actually make a difference!, all of my Lipo’s are all 20C (3s & 5s) and with my new 1512 2d (which will draw!!) but at the same time the 4500mAH should still provide me with 20+ minutes of on demand power / track time?, I'm hoping I just might have a winning combination
I'm just missing my MGM 12012 and I’ll be good to go..
Thanks for your time and have weekend team..
MetalMan
MetalMan's Avatar
06.15.2008, 09:38 PM
Man, as long as you can hold up you'll be driving all day! Should your buggy let you down at any point, you'll have whatever you need to get it going again...
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
06.15.2008, 10:13 PM
I am just a little jealous.
TDC57
TDC57's Avatar
06.16.2008, 03:34 AM
That's the point and the good news to date is I've spent just under $300.00 and if (if mind you!) I was to entertain the idea of building them all into a new working 808 I believe the total cost will be under $500.00. but for that to happen I need (3) diffs a chassis & body and all drive lines, another $200.00 dollars.
Regardless I'm quite fortunate to have spares and that I don’t give a rat’s a$$ attitude what happens to it at the track. Luckily for me it’s been a total champ and shows no signs of wear.
Thank you!..
Fkyx
06.16.2008, 04:16 AM
I'm just a LOT jealous.
pumpkinfish
06.16.2008, 11:31 AM
Just an update after my weekend. I was using Rocco's (Team driver over at RCTech) suggested starting setup and it was almost spot on. I ended up with 1k in the rear diff and a slightly higher ride height but was otherwise identical to his. The thing was as hooked up as could be for the extremely dusty conditions. I had one Mugen driver trying really hard to keep up in practice but kept looping it. I will say this thing doesn't need to be driven hard to go fast!
After work I will try to remember to post that suggested starting setup over here. With a newborn things get hectic quick!
TDC57
TDC57's Avatar
06.18.2008, 02:13 AM
I made the mistake of stopping bye the XRay website today and it costs me -$200 for stuff / bling I really don’t need.. But it Sooo fricken coooool.. What is wrong with me??
Regardless I should have it all by next Friday. So now if / when I do my conversion I will be able to do the entire buggy all at once. (That will be nice!)..
Hello Shaun. Here are your order details.
$78.00 - #353356 - Qty 2 - XB808 ALU ADJUSTABLE REAR HUB CARRIER - SWISS 7075 T6 - HARD COATED + BALL BEARINGS
$5.00 - #352482 - XB808 FRONT ANTI-ROLL BAR 2.2MM
$5.00 - #353484 - XB808 REAR ANTI-ROLL BAR 2.4MM
$39.00 - #352216 - XB808 ALU CASTER BLOCK 10° RIGHT - SWISS 7075 T6 - HARD COATED
$39.00 - #352226 - XB808 ALU CASTER BLOCK 10° LEFT - SWISS 7075 T6 - HARD COATED
$15.00 - #351341 - XB808 GRAPHITE UPPER PLATE
$9.00 - Shipping
$0.00 - Taxes
Your order total is $190.00. Let me know if you approve of the cost and I'll send a PayPal invoice. Just so you know, when we place orders with RC America we have to fax them in. We don't talk with them unless we have a dealer question or something related. Then next time we speak with them about when the 808 kits will be available again, we'll ask about the 808 parts as well. Let me know if you have any questions. Thanks again for your business.
Les Porter
les@rcxray.com
http://www.rcxray.com
bustitup
11.17.2008, 01:20 PM
well wheres the rest of this?....pics please
$9.00 - Shipping
$0.00 - Taxes
Les Porter
les@rcxray.com
auto2
11.18.2008, 08:43 PM
wow it is so much fun spending money on your hobbie. better than so many other ways to spend it.lol
i used to buy all sorts of spares on my previous buggies but this 808 i didnt buy a single spare part and after a whole season nothing( i repeat) nothing broke. i had to change a few bearings and my ft diff housing took a huge hit and broke off the aligning pin so i changed that.( didnt know till i took it apart to clean) you have enough spares to open up a hoby store :-)
