TDC57
TDC57's Avatar
06.15.2008, 02:18 AM
Awesome!! Looking real good..
Question, that’s not a RC monster battery try is it? do you know what your total height is from the chassis to the top of the lipo?, I'm just curious to see how much room you have vrs my 808, my total height is 44.38mm (battery tray and 5s 3700mAH lipo.
Great build, now lets see it get dirty!..
Have a great one..
Nothing!.. Hahahahaaa..
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.15.2008, 02:22 AM
No, its not a RCM Tray, its a RC Product Design Tray. Sorry, i'll have to measure it later on but the tray is thick, thinking of maybe trying to cut it down somehow so the battery can sit lower to the chassis. The battery makes the body sit up a little bit. I weighed the buggy with lipo and everything on and it is 3.7kg but will work on that later
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
06.15.2008, 02:27 AM
Back to work tomorrow so hopefully I will be able to use it at the track in 3 days unless I got picked for Jury Duty which probably will happen
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
TDC57
TDC57's Avatar
06.16.2008, 02:35 AM
Lets us now how it goes at the track!, I hope you have a better experinace than my last one...
DRIFT_BUGGY
06.19.2008, 12:30 AM
Well finally got to give it a test at my local track.
Ran for 24 minutes until the Motor got up to 155F and shut it off. Battery was 95F and the ESC was 110F. Fan still works on the MMM and had to problems with it at all. After it cooled down went out for another 5 minutes on the same battery but the battery holder (gorilla) snapped which sent my lipo flying & flipping accross the ground and ending my day Heard of alot of guys having trouble with the straps snapping but would of thought it would of last longer than 29 minutes.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
06.19.2008, 12:42 AM
Here is a shot of the esc settings I had it at. Just measured the battery voltage and battery still had 19.12V left (3.824V per cell)
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
06.19.2008, 02:31 AM
some heavy duty velcro on both the battery and battery tray works great.....sometimes its even hard to get the battery out fo the tray if you use heavy duty velcro...i buy mine at home depot
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
DRIFT_BUGGY
06.19.2008, 03:31 AM
The Neu motor did get up to 162F at one stage and I was reading in the FAQ section that generally a hot motor and cool RX/ESC usually means it is undergeared. I am running a 14T/46T which makes it geared for 44mph and I really don't need any faster for the track, I was flat out getting up to top speed as it was. Might have to work out how to get some air flow to the motor, I don't really have room to put a fan on the motor.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
06.19.2008, 03:32 AM
Yeah, have to try and work it out after night shift. Might even check around at work since I work at a Alumina Plant
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
06.20.2008, 07:48 AM
Worked out what I am going to try out with the battery strap. It snapped on the small end with the buckle so I am going to
A) Put strong velcro on the bottom of the battery tray and on the battery
B) Use canvas on the short side with the buckle
Will try that out and see how it goes
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
TDC57
TDC57's Avatar
06.20.2008, 11:52 AM
So does that mean to your going up to a 17T pinion or going down to 10T?. I'm asking because I’ve got the 1512 2d s (almost the same motor) I haven’t installed yet. I'm hoping to learn from you experiences.
What oil weight did you use for your center diff??. I used 30K
Thanks for your time DB..
Have a great Friday / Weekend..
Shaun.
DRIFT_BUGGY
06.21.2008, 12:13 AM
Shaun.
The whole chassis setup is completly standard, shock oil/diff oil/shock springs/ride height etc. Just put all the electrics in, test at track and go from there. The standard diff weights in the 8ight are Front - 3000 Centre - 5000 Rear - 2000. Not sure what to do about the gearing yet, will run another battery through it and then try and decide what to do
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
06.21.2008, 12:16 AM
Just finished making the new battery strap/hold down. I got heavy duty velcro from my garage from when I use to work at a Car Entertainment Installation shop. I used canvas (2 layer) on the buckle side of the strap and made in longer than the standard Gorilla strap since I am running a tall/large battery
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
06.22.2008, 04:15 AM
Got to have more fun with it today in my backyard and in my street. Just jumping around on a little jump and flying around the backyard then going out the front and doing some speed runs. Ran for about 30 minutes (battery still had power) but was starting to get really cold and dark. Motor temp was 110F and ESC 90F Battery 85F with same gearing as the track
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
jnev
jnev's Avatar
06.22.2008, 07:57 PM
Very clean conversion! Nice job! Is that the RC Product designs battery tray?
