TDC57
TDC57's Avatar
06.22.2008, 08:24 PM
Originally Posted by DRIFT_BUGGY View Post
My Neu 2.5D come with a little flat spot in the middle of the shaft. I ended up using a dremel and made the rest of the shaft flat (didn't take long at all). I then mounted the motor and realised that the spot that come with a flat spot is where the set screw went anyway
I love you!! Not in that way mind you!, but you just saved me from doing exactly what you did.. I just got a new 1512 2d with the same flat spot and tonight I was going to get out the dermal and continue the mods.. Now I wont!..
Thank you "DB"..
Nothing!.. Hahahahaaa..
Peter Zicha
Peter Zicha's Avatar
06.22.2008, 09:52 PM
Originally Posted by azjc View Post
thats a nice idea...are the square pice of metal you have wielded to each piece of angle iron used to keep the shaft straight?
No , If you look carefully they are on the bottom of the jig , they are exactly 5mm thick same as the shaft . when in the vise they keep a consistant distance on the jig clamping the shaft . without those it would be impossible to hold the shaft
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.23.2008, 12:15 AM
Originally Posted by Peter Zicha View Post
Here is a homemade jig for making factory quality flatspots
Well done, that is a great idea
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
06.23.2008, 12:34 AM
Thank you "DB"..
lol, did you check to make sure it does work the same with your kit?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
TDC57
TDC57's Avatar
06.23.2008, 12:49 AM
No I cant check it now, MetalMan has my buggy, he making me a motor & ESC mount. I'll check it this week, I was just making the assumption that it wouldn’t work, now I'm making the assumption it will..
redshift
RC-Monster Square Tube
redshift's Avatar
06.24.2008, 12:14 AM
Peter- I like the vise within a vice- very creative. You're using one side of a standard vise, so that would be necessary. Otherwise a narrow precision vice would be the way to assure the jaws clamped parallel... even those have some unevenness and your way is foolproof. Very nice!
I've been running without a grind job, no problems so far....
