A few Maxx Questions..
brushlessboy16
brushlessboy16's Avatar
A few Maxx Questions.. - 07.03.2008, 10:47 AM
Hello all, I have a few questions regarding the Maxx Series..
1. Are the Tmaxx 2.5 and Emaxx transmissions interchangeable?
Would i be able to drop an E-maxx transmission into a Tmaxx
2. Is there a wheelbase difference between the Tmaxx 2.5 and the emaxx?
3. Are the transmissions the same length?
Im asking these because i just got offered a Tmaxx 2.5 roller for my raze...
heres what its looking like with stock gearing and the 3905 transmision
Differential Ratio: 2.8461538461538463
Transmission Ratio: 1.8333333333333335
Other Ratio: 1
Spur Tooth Count: 68
Pinion Tooth Count: 19
Total Voltage: 18.5
Motor KV: 2458
Tire Diameter (inches): 5.75
Tire Ballooning (inches): .6
Motor Current Draw: 80
Motor coil Ω: 0.0119
Spur/Pinion Ratio: 3.58 : 1
Total Ratio: 18.67476 : 1
Tire Circumference (inches): 21.83 inches (554.59 mm)
Total Motor Speed: 43132.98 RPM
Vehicle Speed: 47.76 mph (76.71 km/h)
Estimated Adjusted Speed: 45 mph (72 km/h) - 6% loss
Effective KV Value: 2331.51
KT constant: 0.55 oz-in/A
Motor Torque: 0.23 ft-lbs
Final Torque: 4.28 ft-lbs
Final Power: 1480 watts (2 HP)
