emaxxracer15
RC-Monster Maxx
emaxxracer15's Avatar
09.20.2008, 10:03 PM
ok thanks neil
BL FLM E-Maxx (thread here)
MM rustler
emaxxracer15
RC-Monster Maxx
09.28.2008, 09:10 AM
ok so i have made some progress with my build, i have the motor and the MMM. and the final bits and peices are in the mail. however, i ask you this, will using an external BEC increase the chances of my MMM not burning up? ive read that the problems with the v2 can be traced to the BEC circuitry. i will leave you with some pics of the progress,
this is a close fit, will this be dangerous for my batts to be so close to the hot motor?
MM rustler
09.28.2008, 04:58 PM
Your batts will be fine so long as they arent actually touching (air is a poor conductor of heat).
Using an external BEC will take some load off of the esc with regards to powering the Rx and servos, but without knowing exactly what causes some MMM becs to die exactly, at best it wont make a blind bit of difference really; if the esc is going to die, theres nowt you can do to stop it, apart from from very tricky internal pcb modifications...
t-maxxracer32
t-maxxracer32's Avatar
09.28.2008, 05:10 PM
hopefullly your motor will not be too hot because then something may be wrong in your setup.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
10.08.2008, 10:56 PM
As if it hasn't been said enough....It will run very hot, its a Feigao 8xl, even on a good day they're on the verge of meltdown. Generally an 8xl is a 4s motor and runs hot on that, on 6s a123 I can only imagine how hot it will get, I don't give it long till you get a better motor. At the Very least spend the little extra and get a Medusa.
The stiff wire you got from Home Depot osn't going to be good. All the movement when your running it will wind up braking your solder joints since the wires can't move. As far as wire is concerned, if your trying to get it locally and cheap, go to Walmart. Get a car stereo amp wiring kit, or just get 12gauge speaker wire. With the amp kits you can even get bigger wire if you want, just remember that they don't come with much black wire so you may wind up using red for + and -, in which case make sure to label them!
emaxxracer15
RC-Monster Maxx
09.28.2008, 08:09 PM
ya, i think ill just keep the external BEC to unload a bit from the MMM.
MM rustler
anson
09.29.2008, 10:28 AM
Hi, you flipped your tranny right, did you have to get different shafts? Or could you use the ones that came with your FLM chassis. Is it better to have it flipped?
emaxxracer15
RC-Monster Maxx
09.29.2008, 04:25 PM
Now that i look at it, i seem to have flipped the tranny i dont think it will even work right with it flipped. but if you were wondering, the driveshafts that came with the FLM chassis work with the tranny regardless of the direction it is going.
MM rustler
emaxxracer15
RC-Monster Maxx
10.02.2008, 07:44 AM
as my last parts arrive i am in need of assistance in locating a suitable copper braid for connecting the a123 cells together in my batt packs. does anyone know where to get some?
MM rustler
ICUBoy
10.03.2008, 05:48 PM
I just used copper braid made as solder wick. It is sold in places like Radio Shack. Seems to work well for me- love those A123s!
mkrusedc
NeuMaxx
mkrusedc's Avatar
10.02.2008, 10:40 PM
Nice build looks alot like mine. I was going to flip the tranny but just moved the batts instead for better weight distribution.
I have two suggestion...tires...radio...
emaxxracer15
RC-Monster Maxx
10.05.2008, 09:47 PM
That is exactly what I had in mind for upgrades prior to completion of the build. i am thinking about going with the mx-3 FHSS is anyone using this radio? and do you guys know where i can get some cheap 10 AWG wire? i am talking about the super flexable kind like the wire that comes with the MMM leads. i tried Home depot bu all they have is the really stiff copper stuff.
MM rustler
10.03.2008, 09:10 AM
Just search ebay for 'copper braid', plenty of results pop up that way. You will be needing a fairly good iron though, at least 40-50watts or more to make quick, solid joints, without heating up the cells too much.
10.06.2008, 11:19 AM
You can get some nice flexible stuff from ebay, just look for silicon wire usually- airplane and heli sites should have it too.
emaxxracer15
RC-Monster Maxx
10.07.2008, 06:14 PM
i decided to just go with the wire from the depot, it was cheap (less than $1 per foot) ant it isn't that bad. so i built the first battery and it was looking all good until i plugged the balance tap in to the charger and i got a ton of beeps saying the balance voltage was too high. i have ordered the usb kit that will let me update the firmware and hopefully solve the problem until then i will just have to wait.
MM rustler
