Basketti
10.12.2005, 01:05 AM
so when you hit the gas the servo turns anitclockwise? and the breaks go on? you might have the breaks to tight, just losen the screws the hold the breaks on. do you have a pic of the throttle servo and the linkage to the breaks? just incase theres something wrong there like your steering servo
Serum
Serum's Avatar
10.12.2005, 01:34 AM
I don't understand what the problem is Toby, could you please explain?
toby
toby's Avatar
10.12.2005, 07:19 AM
everything on this truck seems to be reversed. i turn the wheel forward (should make it turn right) and it turns left and same with left goes rigjht. and i cannot figure out this mechanical break? On my radio i hit the throttle trigger and that is when the linkage goes, but then i spin the spur gear and hit the "gas" for break and it does not push it enough to break
rc18mt/blade cp
Serum
Serum's Avatar
10.12.2005, 09:55 AM
Okay, you need some adjustment on the break, what way is the brake going? being pushed away from the serv or pulled towards it?
what transmittor do you use? hasnt it got a reverse mode?
toby
toby's Avatar
10.29.2005, 07:59 PM
got the steering fixed, it is sloppy but i will get the cam type servo saver soon.
rc18mt/blade cp
Basketti
10.29.2005, 08:07 PM
nice truck!! I like the look of the lst shocks on the savage, i would have done it on my savage aswell but i sold it lol. yeah the cam servo saver makes a big difference, you should get some bearings for it aswell.
squeeforever
squeeforever's Avatar
10.29.2005, 08:14 PM
is it just me or is the center hole for the motor shaft of center?
toby
toby's Avatar
10.29.2005, 08:15 PM
it is LOL, my dad kind of messed up BUT it works, the shaft clears by like 1 MM though maybe 2.
rc18mt/blade cp
squeeforever
10.29.2005, 08:25 PM
thats pretty close. you might want to think about drill it out some more or getting a dremel and taking some material of of the other side.
Serum
Serum's Avatar
10.30.2005, 05:48 AM
.2 mm clearance allready is enough squee. no need for stress..
toby
toby's Avatar
10.30.2005, 08:58 AM
Serum please answer my PM, it is very important that i get it today, because my dad is leaving.
rc18mt/blade cp
Serum
Serum's Avatar
10.30.2005, 09:53 AM
Sorry Toby, something must have went wrong again with my email, i will fix it right away.
The size for the U profile is 30X30 and it's 2.5 mm thick.
toby
toby's Avatar
10.30.2005, 09:55 AM
30mm by 30mm??? is that the width and length?
rc18mt/blade cp
Serum
Serum's Avatar
10.30.2005, 10:16 AM
It's a U profile. You know the length you need and the distance for the holes?
It's 30X30mm (30 high, 30 width) and the thickness is 2.5
toby
toby's Avatar
i know, i feel stupid, i found that out after, when the numbers are buig my brain must assume it is huge
rc18mt/blade cp
