07.26.2008, 07:31 AM
Update;
I ran 3/4" of a pack thru non stop on the track under race conditions. About 15 minutes.
Motor 1515 1yf , geared 14/48, 4s 6000 mah polyquest cells, MM with a fan no other mods.
Timing set to 0
30% punch control (it stays cooler at 40%)
10% drag brake
Low on the start power (hope these settings helps someone out).
ESC was 135f
Motor 161f
Batts 116
The Losi 8T is an AMAZING truck. I smile every time I open the throttle.
This conversion is by far the most enjoyable one I have done. I have tried alot of different conversions but have they all end up getting to hot and you are always worried the electronics.
