Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
gusti
11.01.2005, 09:57 AM
Hi Crazyjr.
I am running FM and 40MHz, this is different to the US. I think you have 35 or 70MHz. But the length of the waves are not different very much.
I have tried a DSM too with 2.4 GHz. With this radio I tried only very short time and had no problems. But I really have only tested for a short period. So I can not say if there is definitely no problem with the DSM.
I have sold the DSM, because the spektrum DSM DX-3 cannot handle the transmission of an Emaxx.
The only two things I want to do:
1) change the schulze against a warrior 9920 (this will work with the feigao)
2) a friend of mine he is an expert in communications engineering. He will come with a device which can measure frequencies.
So than I have to wait for the 9920 from Mike and for my friend, he is currently on holidays.
But if there are any other things which I can try let me know. I cannot believe this will come from the metal, because in this case all other metal maxxes will have similar problems.
Gusti
Dafni
Dafni's Avatar
11.01.2005, 12:33 PM
Originally posted by Dafni
Maybe you could try to insulate the electronics from the chassis some more. Try to put some foam under the controller and receiver, and put fuel tube over the antenna wire (between receiver and antenna tube)
If you want, I can send you some of the foam I always use.
coolhandcountry
coolhandcountry's Avatar
11.01.2005, 01:56 PM
ON your changing of transmitters and such. did you try different crystals as well?
Peace!
Country
Help support the
Rc-Monster
Buy here
gusti
11.01.2005, 02:47 PM
Hey Coolhandcountry
Thank you for posting. Yes, I have purchased 3 new complete new radios.
- First one with systhesizer, tried different channels.
- Second DSM, worked but tried only short time, because DX3 ist
not working with E-Maxx transmission
- Third Futaba with 3PM with 2 different crystals.
So I have always changed the receiver and the transmitter.
Than with a friend a Futaba PCM. On this radio system you have seen very clear, that if you do not pull out the antenna of the transmitter, after 30 feets, the maxx goes on failsafe.
You can believe me, this supermaxx drives me crazy.
Gusti
Basketti
11.01.2005, 06:19 PM
Why dont you just extend the antenna out of the transmitter?
gusti
11.01.2005, 06:42 PM
Hi Basketti
If I pull out the antenna, then the problem starts at 60 to 70 feets. But there is no fun, driving a supermaxx in such a short range. Also If the maxx starting accelerate himself, it is dangerous. If you take pcm, you are always in the failsafe mode.
Gusti
Basketti
11.01.2005, 09:06 PM
when it takes off by itself can you still steer?
crazyjr
crazyjr's Avatar
11.01.2005, 11:24 PM
Is the antenna on the transmitter tight? I had a similar problem and that was the reason.
