And another new 100A esc (4-8s lipo)
JeffEmbracedDC
JeffEmbracedDC's Avatar
And another new 100A esc (4-8s lipo) - 09.02.2008, 10:04 PM
They are called SuperSimple because they come with a limited range of programming functions and are designed to be plug-n-play.
A perfect ESC for those looking for something simple to use and economic.
Specs:
Weight: 85g
Cells: 4-8S Li Po
Constant Current: 100A
Max Current: 120A
No BEC
Timing: 1/7/15/30 programmable
PWM: 8/16K
Features:
Constant current 100A Max
Li-Poly 4-8 cells
Dynamic Braking
BEC: opto
Auto shut down when lose signal
Slow down at 3.0V per cell Lipo, Cut-off at 2.9V per cell Lipo 0.8V NiMh
Programming options:
Battery settimg
Throttle Rnage
Brake settimg 4 options:
Direction and Cutoff Type
Timing Mode Setting: 1 / 7 / 15 / 30
PWM setting: 8K/16K
Note:
This ESC is OPTO, with no BEC supplying power to your receiver. You will need an extra power source for your receiver. (such as UBEC or Rx battery pack)
If you hear the music tone repeat for more than 3 times, you may need to check your power source to the receiver.
More Details:http://www.hobbycity.com/hobbycity/s...idProduct=7341
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
