TruckBasher
TruckBasher's Avatar
09.05.2008, 10:10 PM
linc, I got mine on ebay.....but he is the only one i've seen so far so I immediately grab it...
E-Slayer direct drive to diff
TruckBasher
09.09.2008, 11:33 PM
so that pushrod is threaded inside all the way from end to end? Or did you just made your way by just inserting the screw?
Nice I like how unique it looks...
Shark413
Shark413's Avatar
09.10.2008, 01:23 AM
Truckbasher, the pushrods were made as follows:
I had some extra 6mm suspension tubes from my Axial crawler. They were about 100mm long, so by cutting them in half they were about the length of the stock Slayer pushrods. I made them shorter so I could use the Revo red spacers to lower the ride height (by leaving the spacers out the pushrod would be shorter than stock). To make the rod ends I took some 4mm machine screws and cut off the heads, leaving about a 30mm long threaded rod. I took a stock Traxxas ball end and screwed the threaded rod into it, then I took this and screwed it into the 6mm tube. I had to tap one end of the 6mm tube afer I cut it, because it was not threaded.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
Shark413
Shark413's Avatar
09.16.2008, 07:08 PM
I wanted to try some different tires on my Slayer, so I bought the MC2 17mm adapters and bolted on some 17mm 1/8 scale buggy wheels/tires. They are a tiny bit bigger in both diameter and width.
Stock on the left, 17mm on the right.
stock wheels/tires.
17mm
17mm
phatmonk
RC carbon junkie
phatmonk's Avatar
09.18.2008, 03:55 PM
Ok I just got my RCM Revo Brushless motormount that I am useing in my Slayer conversion and I just need a picture of how the mount is assembled Please Help..And do I just turn the adjustment for the 2 speed counterclockwise to lock it into 2nd gear.And how many turns?And does this enable reverse to be used?Thanks guys couldnt do it without ya
bruce750i
bruce750i's Avatar
09.18.2008, 04:10 PM
phatmonk: To lock it in you will have to take apart the transmission and modify it.(http://www.rc-monster.com/forum/show...ight=gear+lock) You don't have to lock it in if you keep your brake servo stock and don't care about reverse. RCM motor mount IDK if they are even the same as when i bought mine. Three pieces?
09.18.2008, 04:41 PM
I don't have a picture, but if you blow this one up (from the storefront), you should be able to assemble it from that:
Adjusting the shift screw will NOT totally eliminate first gear. Shifting will be a lot sooner, true, but not instant. And it won't allow reverse or motor braking. Locking into second would be the only easy/free method to allow reverse and motor braking.
Be careful if you do decrease the shift point though, if you go too far, the set screw, spring, and little ball bearing will fall out. It's not good for the gears to have those loose parts floating around in there!
phatmonk
RC carbon junkie
phatmonk's Avatar
09.18.2008, 09:01 PM
Thanks Guys I found Brian Gs thread on locking the second gear.Very stoked with the help I continue to find in the RCM forums.Why doesnt the mount come with at least a photo of a assembled mount?
Tempted
RCM is smarter than me....
Tempted's Avatar
10.26.2008, 08:22 PM
I have a question, how close are the bulkheads and arms to the Revo? The reason I ask is how hard would it be to convert an E-Revo to an E-Slayer? That way the battery trays and motor mounts can stay stock. Just a thought I had. I like the Slayer more than the Revo but have this undying hatred for nitros.
The answer is no. And yes, mine is faster.
phatmonk
RC carbon junkie
phatmonk's Avatar
10.26.2008, 08:27 PM
The Slayer arms as I know will fit the 2.5 Revo with the shorter wheelbase.I think there is a thread about converting a E Revo to E Slayer.
